41 - 56 of 56 Posts
Discussion Starter #41
Well, now, this sucks spectacularly. I wonder where to start? :mad:
202008
Start by ringing out the A wire.
  • Like
Reactions: Jax
PSN intsigator
I’d start a fusible link “A” according to your diagram
Discussion Starter #44
According to the diagram, the "I" circuit should be hot in start or run.
Circuit reposted for convenience. I will, @cjfisher . Both circuits have the C138 connector in common. That is the one that is over the left valve cover
202009
Discussion Starter #45 (Edited)
I am focusing on the blue box. Am I correct in that all the fuse link items - Circuit 38-#1 and Circuit 38#2 should be on the same side as the battery terminal on the starter relay, and they are. They show battery voltage, 12.8v.
202010
Here is the starter relay
202011
Discussion Starter #46
Here is the fuse link A schematic.
202017
Now trace the power through the power distribution box.
Discussion Starter #48 (Edited)
FIXED!
You hit that nail on the head!
I was out at the Power Distribution fuses and began testing. I couldn't remember if I confirmed them but I had my fuse printout copy in the box, so . . .
I decided to confirm them!
The #5 20A Gasoline only OCM fuel pump had a 5 amp in it.
The #10 25A Power Point had a 15A in it.
The #7 5A Diesel Only PCM, Canister Vent Solenoid, and Dual Alt "A" Field was blown.
Now, that fuse box is 21+ years old. All the max fuses were cracked at though someone had dropped something heavy on the box. I had already purchased all new fuses to replace them. I decided this was a good time to do so.
All new fuses, and the battery idiot light is off. Was it the #7? I don't know. But it is fixed!
Discussion Starter #49
I find it amazing that everything led to the "I" wire, but it was the "A" wire. Once that had Alternator voltage (13.6), the "I" wire had batt voltage (13.8) and the light went out.
$%^&*( damn mechanic must have done something wrong and blew the fuse when putting in the first alternator. :mad:
Discussion Starter #50
I could not have done it without you, @heavydoc . I didn't have the values anywhere else and I had already checked all the fuses . . . but probably before the alternator originally went.
As I understand it the "I" is both an activation (turns the regulator on at startup) and trouble line (pulls low if something is wrong with the regulator/alternator). Glad you found it.
  • Like
Reactions: Jax
Discussion Starter #52
I agree! Which is why I spent all the time with that circuit.
PSN intsigator
Glad you got her fixed
  • Like
Reactions: Jax
Administrator
i still say you need to fire that damn mechanic!!! :mad:
  • Like
Reactions: Jax
Discussion Starter #55
What was really funny is that the only blown fuse, #7, was not even on the circuit diagram. Odd.
As you know from your engine rebuild... there is always something missing somewhere in the diagram.
41 - 56 of 56 Posts
