1 - 14 of 14 Posts
trans command from what i understand just ups the pressure VIA computer like a chip, will shift harder and help keep your clutches together a little longer. a VB will provide the same effect but i believe it will shift alot nicer.
Caption This
I've had one on my truck for 10 years. I like the way my transmission shifts. An explanation of how it works is on the Banks website.
Caption This
so you like it? and does anyone know if it will work with an upgraded vb?
Did you read the info on the Banks website? A transcommand is designed to work with a stock valve body and the OE Ford shift programming.
i pulled the trans command off mine, it came with it, I hated the way it shifted with it on there.
1 - 14 of 14 Posts
