1 - 4 of 4 Posts
Just got done putting in my intercooler this weekend. I want to move the map line to the hot side pipe. Can I use a tee fitting to connect the sensor and map line with no ill effects or should I tig another bung into the pipe?
Here is the set up and where the boost sensor is already. And the tee fitting I was going to use.
Or would this be a better style for more accurate readings?
OEM Moderator
Could also move your Tee over around the map sensor as well depending on the kind of fitting you get. Sort of like this. I have my boost gauge set up kinda like that.
1 - 4 of 4 Posts
