1 - 5 of 5 Posts
Back to Civilian Life!!
P0237
P0562
P1119
P1184
P1271
P1272
P1277
The truck was cold, been sitting outside here in the cold not plugged in. Got a killer deal on this truck so I bought it. It has a couple hundred miles on the injectors which are remans that the previous owner put in that he got off eBay from a diesel shop in Memphis. Any help would be appreciated. Also the tcase won't shift out of 4x4 or into low and the light on the dash does not come on. Any tips on what to look for with that?
0562 is for the intake air heater
0237 is turbo boost sensor a circuit low input
1119 is for manifold air temperature sensor
1184 is for the EOT sensor
1271, 1272,1277 are all injector circuit codes
Good luck with those ebay injectors. I'd take them out if it was my truck.
Does it have a manual shift transfer case?
ESOF transfer case. I really could care less about the injectors as long as they all fire... I am just curious about the P1271,1272,1277 codes. The 1184 is because I did a contribution test while the engine was cold.
You should care about the injectors. Bad injectors can fire and not close, leading to a hole in a piston. They aren't a part to skimp on.
The injectors are good and buzz out fine. The have less then a hundred miles on them. If worse comes to worse I can put one of my spare sets in the truck.
1 - 5 of 5 Posts
