1 - 4 of 4 Posts
Friday, a couple of my buddies were inside my truck screwing around. And they tried to see what color my gauges were and then I see then screwing around with the switch. The problem is when you pull it out to the running light position nothing works. When you pull it to the headlight posistion, just the headlights work nothing else. But inbetween the 2 positions you can get all the lights to work. I have the fuse pulled out for the instrument panel cause it blew but the lights still work? Any help here?
Demon Dually
Headlight switch or they messed with the wiring and it is shorted out and that would cause it to blow fuses. It is the brown wire in the center of the plug at the headlight switch.
you prolly blew fuse #4.... cause the same thing happened to me and I thought it was the switch, went out and paid $20 for a new one at auto zone and it still did it. found out it was that fuse after I pulled each and every fuse.
1 - 4 of 4 Posts
