1 - 3 of 3 Posts
My truck is leaking fuel where the ss braided line goes in the right head. Is this just a O-ring or what do I need to fix the leak. It is spraying when the motor is running and smells very strong.
All done now
Try tightening a half turn. It uses a ring, but it looks like a cut off piece of tubing. In fact if you knew the right size, you could use exactly that. Someone will pipe in.
I think it is comming from above the fitting where the braided line ataches to threded fitting. Is this a hp line or return line?
1 - 3 of 3 Posts
