1 - 13 of 13 Posts
Banned
The injectors don't really care, as far as A-codes, B-codes, Hybrids and so on. But, the heads/fuel system does.
On my truck with the factory lines still feeding the heads I found that the truck responds better and smokes less at 60lbs than at 68. I believe the fuel pressure was way high pre-head and falling into a serious low pressure zone (compared to the higher pressure ahead of the head) in the fuel rail in the head causing serious aeration issues.
Pump sounds 200% happier and the truck runs cleaner and crisper. VERY noticably cleaner and crisper.
I run 60 with the stock lines.
Just two cents worth.
<- Sums it up
64psi here. I have not tried to mess with the fuel pressure yet.
I have been too busy trying to adjust the wastegate to control some boost. This thing makes so much power with B codes that I have yet to floor it. My wife says I am chicken I think she may be on to something.
Keep Strokin'
Banned
Why not 200? Why not apply the same 3800psi ICP logic to the fuel pressure....
:poke:
:D
1 - 13 of 13 Posts
