1 - 3 of 3 Posts
I have a 2003 F-350 6.0l dually it has a dana rear axle. I have a early 99 parts truck its a f-250 gas motor. I want to know if i can swap these rear end i want to put the 250 rear end under my 350. And of corse the 250 is a single rear wheel. Thanks guys
if both trucks are pickups and not cab and chassis, then you can swap them.
now the list of buts
the gears might not be the same - if 4x4 this is a big deal. also good to know for towing reasons ect
the sensor ring in the rear diff might have a different number of teeth which would mean you have to reprogram your speedo.
the front is still gunna be a dually.
1 - 3 of 3 Posts
