1 - 7 of 7 Posts
Moved in
Saturday's rear brake job has turned into new bearings and seals since both sides were leaking. I have new bearings and seals but I need the part number of the o-ring on the inside of the axle flange. The local Ford parts guy was clueless.
Truck is a 2000 F 350 SRW 10.5" with 3.73 gears.
I usually use a bead of Permatex Right Stuff sealant=clean both mating surfaces with brakeclean apply a thin bead and install.
Moved in
Parts guys said there is no "ES" but there is an "E5" comes back as a gasket. I'll let you know what comes in.
1 - 7 of 7 Posts
