1 - 3 of 3 Posts
Just like the title says my tranny is pissing me off the shifter is loose my tranny starts to jump because its about to go out the hardest shifting truck ever been on and thought about putting a zf6 in it any opinions on this.
New guy
This may or may not help. My shifter gets sloppy after a few months. Turns out it's a common problem easily fixed with a star bit. Under the dash, up above the brake pedal. No need to remove anything, just stick your head under with a flashlight and torx bit and tighten . If u can't find which ones I'm talking about. While looking up, use your left hand to wiggle the shifter. You will see the two bolts to tighten than. Gl
1 - 3 of 3 Posts
