1 - 2 of 2 Posts
lets get smoking
ok just so you all know my truck died on me this morning going to work the torque locked up. well i was just going to put a new torque in it but my buddies dad has got a two wheel drive zf-5 crew cab long bed that is a 95 and my truck is a 97 but he said if i could change it all out and it would work he would give all the parts that i need off his truck ( thats been sitting for 2 years) for free if it worked.. so my question to all of you is can i make his 2x4 zf-5 work in my 4x4 that has a e4od? would the tail shafts interchange so i could fit my transfer case to the 5 speed and would i have to get drive shafts shorten and lenghten or would everything fit. i mean i have a hole donor truck to work with but i have a standard cab 4x4 and his is a crew cab 2x4
The Fireman
I'm not 100% on this but I don't think this is going to work for you.
I think the zf5 2x4 and the zf5 4x4's are different. You would have to be able to change the tail housing to the same tail housing as the e4od with the same output shafts and everything for the transfer case to mate up.
1 - 2 of 2 Posts
