1 - 4 of 4 Posts
Hi, I am in the final stages of a zf 5 swap after my auto trans died in my 97 psd. I did not get a new steering column cause I swear at some point I found a post where someone was talking about a piece to cover where the shift selector comes out of the auto steering column. Has anyone ever heard of such a thing? I really don't feel like swapping a column unless I can't find a cover to delete the auto shift selector. Thanks in advance!!
You may have a issue removing the key if you don't have the auto selector in park or the key release button from a manual.
When I did my 95 I bought a manual column off ebay and just swapped the parts over. It isn't hard, just pull the lower dash, steering column cover and 4 nuts holding the column up and you will have enough access to remove all the parts which are held in with torx screws.
1 - 4 of 4 Posts
