problem is your 2006 has 28k on it
inside the turbocharger is unison ring that controls the veins. Most likely it is rusted and stuck. A ford scanner can do turbo boost test to very. Remove the turbocharger remove turbine housing and clean the corrosion off reassemble reinstall with updated feed and drain tubes. pull you egr and make sure its clean while your at it
