1 - 2 of 2 Posts
I have a Revtek 6" lift, procomp shocks, and set of 37" Nitto Trail grapplers on 20" rims....
I ####ed up and let the fronts get a little cupped.... moved them to the back... been running it that way for about 8 months and now it seems that the fronts are cupping again!
Annoying!
Is it a tire issue? Because I LOVE the look of my nittos, and I would like to replace them with the same tire...
Shock issue? Front end bushings?
Any help is much appreciated!
I had the issue with my excursion. had the front end alined twice, went though all of the mechanical components and then realized i have a 90deg turn into my driveway. Now i go around the block and loop back which makes it a straight run into my driveway. No more cupping on my front tires. Just rotated them last week and after 10k miles no cupping. So if your mechanical parts are ok and the alignment is ok then look at where/how you drive. ..any frequent sharp turns? good luck.
1 - 2 of 2 Posts
