1 - 8 of 8 Posts
I picked up a set of 6" skyjacker front springs today...They measure around 11" from ground to the top of bottom leaf...(make sense?) Flip spring over stand it up run tape from ground up...At center pin....
Just wanna make sure they arent 4" springs....They look like alot more arch then my 4's...
thanks
Discussion Starter #2
cmon brad i know u got a set somewhere!!!!
C,mon guys....:)
Do they look like these?
6" Skyjackers, still got em in the shed. I will get a measurement off them sometime today. They rode like bricks!
Yes and no.....
6 leaves yes....
Looks like a degree shim bolted in pack same as mine....
But the wrap at the end is larger then mine...The springs that i got also came with new poly bushings from skyjacker...Mine have a smaller wrap main leaf...My Superlift springs have the large wrap main also...
The ride improves ALOT with the RSK....
A measurement would be great when you get a chance....thanks
Heres mine....
Ok so they measure the same...Cool thanks a bunch!!!
1 - 8 of 8 Posts
