1 - 10 of 10 Posts
currently am running a 1.15 housing and has been ok for everyday driving(a little laggy). But i just hauled a 5th wheel 20,000lbs. gross up to dodgeville wis and i incured some surge and had a hard time accelerating below 2000+/- rpms. so i was wondering if choking my housing down to a 1.0 will help with my lag. any input is appreciated.
Caution! May Blow Smoke
I don't think its your 1.15 housing giving you a problem. I pull 24-25000 lbs alot and I don't have any problems.
how much lag do u see with ur 6 speed? i see that u have 4.10 gears makes me think that would help some when towing
Going Crazy
Ill trade ya housings...
Wheelie Dude
When its laggy are you getting alot of smoke? If its smoke free you may have a fuel pressure issue. You should not get any surge out of a 1:15 housing, only reason I could see you surging with that housing is lack of fuel. If it surges now a 1.0 will only make it worse.
yeah there is smoke on the low end - depends on which tune. This is the first time that i have gotten this turbo to surge(had turbo about 7 months, inj. about 5 months). i think getting new tunes for it will help because my tow tune from swamps is very low on power(acelerating is very slow process). but even when i am unloaded if i shift easy into any gear then hit the pedal even in the drag tune it seems it takes about 3 to 4 seconds+/- for the turbo to lit. i know that there will be some lag but the 38r in my mind is not a large turbo and i would think spool up would be quicker than that. For towing purposes i feel i should have better response with this turbo and that is why i was wondering if the 1.0 housing would have better response and minimal surge.
The Fireman
I have the 1.00 housing on my 38r but keep in mind I have ported heads.
I have never ran the 1.15
Get new tunes and see what happens. I know when i ran the swamps tunes for a little while with my setup the turbo was laggy and smokey in some of the settings and I could get it to surge.
Not bad mouthing swamps at all but I like Matt's tunes better for DD/Towing, Little smoke and no turbo lag or surge.
The swamps tunes once the turbo lite felt more powerful though and I liked em but just not for DD/Towing.
So get some different tunes and i think that will fix your issue
I am having same issue with stock inj. all smoke now power? lot of turbo whistle it is all u can hear when towin?
I think its your tuning as I also have a 38r with the 1.15 housing and I am really happy with it towing or DD
1 - 10 of 10 Posts
