1 - 4 of 4 Posts
Just wondering if anyone had made a 58 tooth outhof the factory 12 valve damper? My thoughts were to cut grooves in the outer edge of the damper and use 2 of the three wires from the factory cummins sensor. Anybody tried it or know why it isn't a good idea?
I have used the Digital Dakota box dc-1 in a few swaps. works flawlessly. Reads off of the alternator field wire into microprosessor, out of micro, into vehicle cam signal wire, back dash harness. I tried a tach tone ring setup once. didn't work with a fluid dampener. So I went with the DD box.
guy doing a 12v conversion on comp d was talking about getting a 6.7 damper.. it has the 58 tooth tach ring on it already..i think??
1 - 4 of 4 Posts
