1 - 5 of 5 Posts
So I just put a 2.5" leveling kit on my truck and ordered née 18" mamba wheels and what was supposed to be 35x12.50 but he sent me 325 which I'm pretty sure are 37's not home right now but they just came in and my brother called me with the news. Anyway these will fit?
Lovin Life...
325 denotes width in mm. That is approximately 13 inches wide. The height is dictated by the next number. 325/60r18 is equal to 33x13x18. 325/65r18 is equal to 35/13/18. I ran, 325/65/18 with just a level, they rubbed at full turn on drivers wheel well. Fit well other than that.
Those are 35x12.5x18 and if you got 4.5 backspacing they will fit with a small bit of rubbing likely on the wheel well plastic at ful lock. Mark the palces with white chalk then get a heat gun paint stripper and soft and deform the plastic so its no longer an issue. You can also zip tip it back as well. If you plan on hard 4x4 with them I would check at full compression all the way thru each turn direction.
1 - 5 of 5 Posts
