1 - 6 of 6 Posts
Big Mac
I recently replaced my center driveshaft bearing as it was gone. While I did that I replaced the rear u joint. The shutter I had off the line is gone but I have a shutter/vibration at about 50mph in OD. If I give it some more pedal it settles down. It's not horrible but you can feel it in your feet and see the mirrors shake at that speed. Please help!!!!!!!!
Big Mac
Discussion Starter #2
Oh and I had the driveshaft balanced as I forgot to mark the yoke location to the splines
When is the last time you had tires balanced and wheel alignment done? Have you greased the u joints?
Big Mac
Tires are good. Just had them checked. I just put the other 2 u joints in and the same issue. I pulled the diff cover but everything looks good. I am at the end of my rope. please help.
Big Mac
I have found a bit of up and down play in the tailshaft on the Transfer case. I bet anyting that is the issue. Has anyone ever replaced this and how dificult is it. Maybe a step by step guide would be the best. I cant find anything on the web.
Big Mac
Ok no I found that the driveshaft was out of phase. I phased it correct and had to flip the rear yoke on the front half of the shaft 180*. It took most the vibration out but now that I did that will I have to re-balance the shaft?
1 - 6 of 6 Posts
