1 - 3 of 3 Posts
zfsix4our
I just switched over to amsoil synthetic to extend my drain intervals and protect my engine to the fullest. On the back of the container it says with the 6.4 L OEM drain intervals are needed. Does it only require this because of the DPF because some fuel makes its way into the oil during the regen? Im removing the DPF in about a month anyway. I was just curious because Im not really gaining the full advantage of synthetic oil.
Diffrent Strokes
Its got to be because of the dpf as you suspect. You may also look into a bypass filter as well.
zfsix4our
Yeah I plan on getting that and a coolant filtration system too,I want to make this thing last.
1 - 3 of 3 Posts
