1 - 5 of 5 Posts
Hey guys I know the crew cab guys have been doing it. But I have an extended cab and I'm trying to figure out what set of steps to order. Know of anyone with an extended cab that has done it ?? :tree:
Did you look at my write up in the library?
did this exact set up from his write up on my 96, and it was exact. 18-20 degree is the amount of angle I needed to get it exact. all his info was spot on, the wiring was a bit tricky, he was absolutely correct, but to find a few of the colors he talked about, I had to remove the harness cover and tape since those colors meet together and change mid stream in the harness, but other than that, works like a champ for over 2 years now.
1 - 5 of 5 Posts
