1 - 5 of 5 Posts
i picked up Auto enginuity with the full ford bundle hoping i could perform the power balance to show which injectors are going etc, when i pull it up anthing over idle sends the bar haywire? on the ford ids it allows you to rev it up and it shows dips in the graph where the injectors contribution percent is can ae not do this?
It only works at idle. You have to use a combination of cylinder contribution, power balance, and injector buzz tests to pick out bad injectors. Sometimes it won't pick out a bad one unless it's really bad.
harley master
If you hold a steady rpm, and restart your power balance test it will so it any rpm. I do it with mine all the time.
1 - 5 of 5 Posts
