1 - 20 of 36 Posts
· utah get me two
Discussion Starter · #2 ·
after posting ,i realized i should also say,the few times i have read codes after getting the ses light it has allways been 1211,i dont have a reeader and am assumeing that it is throwing the 1211 code
· 2010 BOB Points Runner up
If the P1211 code all the time like under normal driving, and not hard into then you probably need a new IPR
-Michael
· Registered
I'd check to see if the IPR is leaking, then call up Joey and order a Terminator II with that fancy R-IPR.
If the SES light comes on after 30+ seconds of heavey throttle then the tunes are asking for more oil than the pump can supply. If you are setting a P1211 code under daily driven type conditions then you probably have an issue like crap in the IPR, IPR orings, etc.
· Banned
Can you ever feel the truck surge in power with a very crisp "Timing" sound? This is usually a sign of a stuck IPR coming "unstuck" and the ICP jumping up quickly advancing your effective timing, giving the engine a very raspy sound until the IPR duty cycle is gotten back in check.
I had a sticky IPR and although it never set the SES, I had the "Over/Under" ICP code everytime until I took it out and cleaned it.
There is a very good chance you might have ICP higher than desired if you've got a sticky IPR. If the truck is setting the code during say, steady rpm, cruising situations, like rolling down the interstate, then I'd look into the IPR seriously.
1211 is just as easily set by high ICP as low. It's an "out-of-bounds" error. It can be from either direction, although usually from the lower of the two.
Good Luck.
· utah get me two
Discussion Starter · #9 ·
it happens when i am going say 20 mph and jump on it,or if im doing 55 mph and slam it to the floor,not every time but under those cicumstances,and allways when im towing i get it. the ipr is new about 10-15 thousand miles ageo...
· Registered
Sounds more like a pump at this point. Might be worth pulling the IPR off and some new orings. Also might see if you can get a scanner to see what the pressure is actually doing, but it's probably the pump can't keep up.
· utah get me two
Discussion Starter · #11 ·
ok my thoughts as well,so is there a single pump that put out more pressure than the oem one.you know a hotter pump,or is the next step up big oil,was looking for an option to the cost of duel pumps......
· Registered
Terminator will be releasing the cardiac arrest soon. (hopefully :poke: ) which will be less cost than the dual setup and provide more oil than stock.
Joey could answer how much more than stock, but I believe it is targeted to support up to stage 2 injectors.
You can also ebay and scavenge for another used pump, and send TE both of yours. I hear if you bribe Joey with candy, he'll do it that way and make you a deal. :D
· Banned
Maybe if Joey Builds it himself he can save himself the constant ridicule of it's not being "Big Oil" as was the case 24-7 with the 20* pump that I and many others ran for so long with great success.
There is no place for medium oil on a powerstroke........well unless Joey himself is the one making the money selling it I guess.
:confused:
It's funny how things like that seem to work out sometimes. :lame:
· Registered
Charles, can you explain why the 20* pump was called a 20* pump? There are modifications done internally, but in the wrong place.
The CA will have some new internals, not just modified. Medium Oil's goal is to increase flow slightly and stop the SES light.
FWIW, I agree that Big Oil is the best alternative.
· Banned
Just calling a spade a spade. It used to be that a place for "Medium Oil" didn't exist. But now apparently it does...
That coincides with your soon-to-be release of just such a product. When Swamps with the 20* or Bob with his Pulse, were selling a product producing the same results (enough oil to fully support a Stage II/Hybrid injector) it was deemed useless. As if there was no need for any more oil if not "Big Oil". Now apparently a window for "Medium Oil" has presented itself as a valid and worthwhile venture. Could it be that at least on some level, your running opinion is based upon what will sell the most Terminator products?
Or is this just a foolish mis-observation on my part?
If so, then I appologize.
· utah get me two
Discussion Starter · #16 ·
well my thoughts are this.i have pmrs and will continue to run the stock sticks,but want to get all i can out of them,so with oil tunes and a turbo,wouldnt medium oil and big oil be the same affect on my truck ??? so if im correct medium oil would fit the bill,at less cost makeing it more apealing to me and i suspect others who want oil but arnt total power freaks.now if im wrond in my assumptions i need to know,cause little in life pisses me off more than to spend,on ####ty upgrages.........
· Registered
:hehe: :hehe:
You say your going to get oil and a turbo but that's it stock injectors are staying :poke:
Give the PMS time, you will be thinking different shortly :D Once a horsepower junkie, always a horsepower junkie
That is unless you have more will power than I.
· <<< THE GAUGE WHORE...
I agree... you will be in the same boat I am or very close... I was going to swap in Forged rods this winter... now its just happining sooner...
· Registered
Charles, no problem. Right now, NOBODY offers a Medium Oil system. That is the only reason I'm working on it. To be totally honest, the CA is more work for me then building a TE kit. I am the first to discourage people away from Medium Oil, because they will outgrow it.
racehauler nailed it!
HEY... I want it... Any chance it will be ready before the week of the 8th... when she goes under the knife?
1 - 20 of 36 Posts
