1 - 4 of 4 Posts
Big dumb redneck
Started noticing an issue after I put these tires/rims on. When I'm going over about 50mph and let off the throttle, the truck will dart to the right. It's not like it'll dart off the road, but it does do it pretty sharply. But, as soon as you get back on the gas, it will straighten back up. I noticed it was doing it slightly since I put these tires on, but yesterday I raised the pressure in all 4 (55 up front, 70 in back) and it seemed to get worse. I figured if it was an alignment issue the truck would always want to pull to the right. You let go of the steering wheel and it tracks straight. I'm stumped! I've gone over everything I can think of. Truck has leveling kit up front and 4" blocks in back.
Any ideas??
Demon Dually
You either have worn steering parts or are just in need of an alignment. Are the tires brand new? If not they could have worn so that it would pull right. Have you tried wapping tiresand rims around on the truck, as in moving the right front to the left rear etc.?
Big dumb redneck
Tires were brand new. Only had them on the truck for about a month or so.
still worth a try
1 - 4 of 4 Posts
