1 - 8 of 8 Posts
check out centerlinewheels.com
the wilderness series bullet and scout both look close to the factory alcoas but with ten holes not 8. Both are available in 16x10 with a 3200lb load rating. I someday hope to get the scouts in 18x9.
STILL LEARNING
You are going to have a hard time finding a FORGED wheel like the Alcoa. Almost every aluminum wheel is cast aluminum But centerline wheels are forged and expensive as hell!!
Eagle Alloys has a wheel that is very similar to an Alcoa and way cheaper Here is the specs. Model# 0589-7088 / SIZE 16x10 / Finish Polished / Bolt pattern 8 on 6.5 / Offset -24 mm /Back spacing 4 1/2 / Weight rating 3420 lbs./ Weight 24 lbs.
1 - 8 of 8 Posts
