1 - 7 of 7 Posts
Is there anywhere else to get a relay for my airdog 2 other than airdog? Im jw if I can go to my local parts house and pic one up.
Any common 12 volt 30 amp relay will work though you don't realy need a 30 amp relay.
I may have the AD relay on the shelf. I wired mine into the fuse / relay box.
Proud PSN Sponsor!
Be careful, there is something different about the AD relay as compared to a "standard" bosch-style relay. I've had a few customers that had to pop the wires out of the relay holder and move them around to use a "standard" relay. If you plug in a standard relay and the pump runs all the time, that's the problem.
I do still have the AD relay from my kit. If you want it PM me your mailing address and I will drop it in a flat rate box and send it out.
1 - 7 of 7 Posts
