1 - 3 of 3 Posts
Ticking time bomb
i have to have an air shut off switch for next pulling season just wondering how you guys are doing it and if you have any pics.
HRT Performance
There are several ways of doing it depending on how much money you want to spend.
Pre-turbo guillitene (sp) - a slide that slams shut when activated - this is the most common version found in pulling applications - but can be expensive to purchase as most sold for pulling are machined out of billet. There are some DIY ones out there that use a "blast gate" fot an air duct system and can be built pretty easily and cost effective. CompD has some good posts about these.
Pre-turbo butterfly - same as above except its a butterfly - again mechanically actuated or electronically actuated.
post turbo butterfly - a butterfly valve installed between the intakes of the heads and the turbo - it must be air tight so it doesn't cause a boost leak - I have seen them mechancially actuated and electronically actuated. There are comercial companies that sell these for OTR applications. Brandon aka "JoeFarmer" on CompD has on his S-10, Scott aka "BigBadDodge" use to run one on his first truck - his new truck uses the first method if I remember correctly.
Crazy Talk
here is mine. used a shut off for like a sawdust collector as jason mentioned.
1 - 3 of 3 Posts
