1 - 3 of 3 Posts
Hi, ive noticed when i shut my truck off and if i listen i can hear bubbling sound coming from driver side. Im sure its coming from the degas bottle and it doesn't bubble when truck is running its just like as soon as i turn the key off air is released into the bottle for some reason and it slows down and stops about 10 seconds later. I also have egr delete on the truck. and also may have a head gasket problem. But besides head gaskets what could be making this happen. The coolant looks clean. and im not loosing coolant.
Thanks
Newbie
If you drained the coolant when you did the EGR delete, then yes you could have air in the system. I didnt have too much trouble getting the air out when I flushed mine. After the flush though I left the cap off and let the truck warm up, topped it off and put the cap back on. Drove it for a while and then topped it off again. Good to go.
thanks for the reply. I forgot to say that i actually did that also. and kept adding coolant till it remained steady.
1 - 3 of 3 Posts
