1 - 7 of 7 Posts
FARMTUF
I have a AFE stage 2 air intake on my truck and I'm wanting to do away with the air filter. I'm trying to find a "throw away" filter to replace it with but keep the AFE piping and box. My only problem is i can seem to find a filter with a 5.5 inch inlet. Thanks for you help!
OBS Stroker
FARMTUF
Thanks nodge, but I just decided to do a 6637 swap, just got a 4in pipe going to it....but I did look up s&b and I think ill keep my afe close and go ahead a buy a filter for it too
Do y'all let the 6637 filter rub against the bracket that holds the rearward stud for the factory air filter box?
yep yep. let her ride where she lays..
Thanks! I like the clean routing with that blue hard pipe.
I drilled a hole in the bracket I just asked about, the one that is also the mount for the fuse box, and 'mounted' the air temp sensor to it rather than just let it flop around. I had to remove the nuts from inside the fender well to raise it enough to drill the hole.
1 - 7 of 7 Posts
