1 - 13 of 13 Posts
Driving back from SoCal last week on Friday with the A/C on coming into the SJ valley. All seemed fine until about 20 minutes at which time the cold air began to fade to warm. If I shut off the A/C and wait 30 minutes I can then turn it back on and it will blow cold air for about 10 minutes and it is back to warm air once again.
I am hoping it is the A/C clutch that is failing once it gets warmed up. I don't have much experience with A/C, but understand the operating principle well enough to fix my problem if I can get some insight from the group as to what to look for.
Any help is appreciated in advance.
Thanks,
Pat
All done now
Could be the clutch wearing out. You can do a temp fix on it by pulling off the front nut on the clutch and removing the shims. Like I say, it is a temp fix. My temp fix made it through last summer, I am going to ride it as long as possible.
If it was the clutch which I thought it might be, you can buy replacement clutch /clutch field coil. I don't have a/c manifold gauges unless I buy some. So I won't have high/low readings.. I would have already done that, but thanks for the suggestion bbbxcursion.
BTW, the clutch replacement procedure mentions special tools being used on special tools used on the clutch pulley.. LOL
All done now
You can get that bolt out with the tools in your truck box. Nothing special. To replace the clutch, all bets are off.
Ya, the bolt comes out with a standard socket, but here is where you go from there... haha
Place the A/C clutch field coil on the A/C compressor with the A/C clutch field coil electrical connector correctly positioned.
2 Place the special tool on the A/C clutch field coil.
3 Place the special tool on the special tool.
4 Use the special tool to install the A/C clutch field coil until bottomed completely against the A/C compressor.
...and that's F&^*in special
Actually one of the special tools is a spanner wrench and the others are a couple Field Coil Installation tools.. 3-4 inch cylinders that are used to seat the field coil on the compressor. They can be made.. I am just trying to find out if it needs a new clutch or not.
All done now
I know what you mean. It is actually harder to buy a clutch than I thought. A/C compressor rebuild shops have been trying to stop it for years.
I remember when I was a kid, you could buy a starter rebuild kit, an alternator rebuild kit, a master cylinder rebuild kit, etc.... from any parts house. Lot harder to do now.
Here is the one I found a few minutes ago.. A/C Clutch I have not ordered it so I don't know if they really have one.. You never now how long it may take once ordered.
sounds to me like it's freezing up either at the evap or the expansion valve or orifice tube which ever system it is.
I am going to buy some manifold gauges, found them at Mechanics Tool Supply for $70.00. Don't think i will get much farther w/o these. Meanwhile I will keep digging around.
Anyone know if these will do double duty on home HVAC, just wondering
Genius, when I drink
Pretty sure the connections are not the same. Plus, home uses a different refrigerant than R134a.
To bad you aren't a little closer I got a gauge set you could use.
Let us know what you find; I usually put the gauges on and get a reading before turning on the a/c, then with the a/c on I check what the pressures are at idle and check again with the engine at 1800-2000rpm.
Good luck!
I would bet your refrigerant level is low. Buy a one can recharge kit, they come with a gauge that is color coded.
The only warning is purge the line with refrigerant before tightening the fitting. It will save you $60.00.
1 - 13 of 13 Posts
