1 - 19 of 19 Posts
Laces Out
my 97 reg cab f250 has firestone ride rites....anyone know proper air pressure i should run? or is it something i need to play with to get just right??
just depends on how much load you have on. I usually ran enough psi (up to 80) to keep the back end from sagging when loaded.
Mike,
I think u can adjust the air pressure to whatever you feel is right. Im not sure tho, but i dont think there is a set air pressure.
Min 5 lbs to keep the bag shape. I belive the whole system is rated for 150psi considering it was installed correctly.
My friend has these, max is 100lbs unloaded I believe.
I would run them low empty, loaded just depends on the weight. As much as you need to keep the truck level up to 100psi.
i didnt know u had a friend gregrob!!! maybe an acquaintance!!!
Local Machine Gun Builder
On my reg cab I've found I have to run less pressure than my longer trucks when empty or it rides like hell.
My 2000 I run 20 psi with the velvet ride shackles and it rides like a Caddilac.
Bleau May
I have Air Lift bags and the minimum is 5lbs and max is 100lbs like already said. I only add air if needed to keep the ride softer.
I run 30lbs empty and it rides great. 60lbs with my 34ft fifth wheel which goes 13,200 loaded
Bill
any body running them in the front?
Who has the best air bag kit for an OBS Dually?
Thanks,
Michael Pliska
OEM Moderator
I run airbags up front. Was my solution to avoid the F-250 spring sag and tilted tires.
Tom
Bill
what do you think of the ride with them in the front. I know when I get over 20 psi in the back you can feel a diffrence.
OEM Moderator
I only run 10 psi up front so the ride is not effected. Just enough to support the front springs to prevent sag.
Tom
dinnerbooter treasurer
The 2 big names in air bags are Airlift and Firestone. I have Airlift's in the front of my truck for the snow plow. Simple design and look to be beefy enough. I have heard the same thing about the Firestone ones.
1 - 19 of 19 Posts
