1 - 20 of 23 Posts
Aeromotive A1000 fuel pump with -8 fitting on both ends. Fitting can be removed. Just had Aermotive look it over because terminal on top were loose. 250 obo.
Thanks
Mike
That a good questions. Any idea how I would find this out.
Demon Dually
The marine regulators are all black and aluminum colored. The A1000 regulators for fuel injection only come as either a -10 or -6. At any rate you could get either brand new for less than 150 just to give the OP a heads up.
Demon Dually
Sorry bud. I didn't read your post thoroughly enough and just assumed it was a regulator. :doh:
Busy Busy
For any possible buyer/installer of said pump... it is reccommended to run a 10an inlet........
wheres the fat chicks?
will you take 200
Busy Busy
Discussion Starter · #13 ·
Yes it will work. You will need a regulator to go along with it. Along with a filter.
Busy Busy
and another filter (water seperator), and a myriad of other fittings and mounting hardware.
okay well i just bought a 6.0 pump so i guess im out of the running, i was sort of thinking this was the regulator, i wasnt totally with it last night when i was reading this
Busy Busy
A 6.0 pump :doh:
A 6.0 pump :doh:
I got it for $50.... is there something else for under $100 that i could use to get me to 500hp?
Im not looking to lay down 740 like you haha, i just want a reliable 500 and the 6.0 pump was super cheap
Busy Busy
I don't make 740, I make 509 :poke:
And a stock SD pump or two will take you there ;)
But a 6.0 pump will as well. And it will seperate fuel from water all in one step rather than me needing an external filter for that.
No single SD pump will keep up with what i'd like to do, so i'd need 2 of them. Find me 2 of them for $50 or even $100
1 - 20 of 23 Posts
