1 - 4 of 4 Posts
A friend just, upgraded his fuel system on his 03, and gave me his factory fule pump. My question is would it hurt anything if I install it on my 96. Dont have the cash for the whole fuel system upgrade right now. So would this help my truck, and would there be anything I would have to do other that mounting it
to the frame rail,hooking up the fuel lines, and powering it? Thanks
I may be totally wrong but I don't think it will work because the fuel bowl can't handle that kind of pressure... You will need to delete the lift pump and fuel bowl and add pre and post filters with the electric fuel pump as well as get a regulator...
Hopefully somebody else chimes in but that is my understanding..
Unless you do the complete fuel system swap, the electric fuel pump from a Super Duty will destroy the fuel bowl. The fuel bowl on the OBS 7.3 is only designed for low PSI.
1 - 4 of 4 Posts
