1 - 7 of 7 Posts
Was just curious if you guy's bother to turn the a/c off when you go to start up your truck or if you just leave it on? I have been turning mine off when starting, but just curious what yall do.
Don't EFN worry about it
I turn off all the acc. when I shut all my vehicles off, just a habit.
I turn the radio down but not off and the air down as well. On cold mornings I cut everything off because my batteries are doodoo.
OEM Moderator
The company car gets turned off and on all day long with the AC on with no apparent ill effects.
Demon Dually
It is a matter of preference and not neccessity unless your batteries are shot in which case you should replace them so you don't get stranded.
PMS medication required
Unless your system isn't working right the AC clutch will not be engaged when starting your truck. It will engage a few seconds after the truck is running.
1 - 7 of 7 Posts
