1 - 4 of 4 Posts
Hey guys I was just wondering if anyone knew the size (width) of the stock rims on a late 99 F-350 srw. Also, i was wondering if i could run a 315/75 R16 (35x12.50 R16) on theese rims. Thanks
Pretty sure there 16 x 7.5 or 16 x 8...
"Smoke A Lil Smoke"
there either 16x7 or 16x7.5 . Technically you are not suppose to run that wide of a tire on the rims but it has been done many times. The main thing if you do would be to make sure you play with the air pressure to get them to run even across tread. The bad thing is I have seen some tires crack around the outside because they are sucked in to much. bfg A/t's seem to be bad for it. If it was me, I would pic up some 16x10's I have seen them cheap on craigslist many times because they are not a popular size.
I haven't run 305's but a 285 will fit with no problems at all. If you can find them I'm pretty sure a 295 will also fit without clearance or rubbing issues.
1 - 4 of 4 Posts
