1 - 9 of 9 Posts
STILL LEARNING
Ok guys. I am putting together my 99 F550 4wd
I need to know quantity and what OEM calls for. Not looking to spend a fortune
Rear axle dana 130
Front axle dana 60
Engine (im putting in 15w-40 Valvoline)
ZF6
T-case(manual shift)
Engine coolant
Power steering fluid
I work at Advance Auto Parts and we have a program in the computer that gives all the fluid levels and types of fluid to use. Drop by or call and they will tell you what you need.:ford:
STILL LEARNING
their computer coudnt tell me anything for the rear axle.
And I am not to confident on the regular ATF they told me to put in the 6 speed
It says i need a password to sign in
I found capacities under the owners guide 1st printing.
STILL LEARNING
Thanks.
Incase anyone was wondering
D60 front axle 75w/90 3.8 pts/1.9qts
D130 rear axle 80w/90 24.5pts/12.25qts :eek:
ZF6 Mercon ATF(regular) 5.8qts
T-case Mercon ATF(regular) 2qts
You are going to go broke filling that rearend, 12.25 qts! good lord!
1 - 9 of 9 Posts
