I haven't put a gauge on it yet, but it fills the fuel bowl very quickly when the key is on.And your fuel pressure is where it should be , fuse and all are wright on ? Gov Holmes
Then that probably isn't the problem.I haven't put a gauge on it yet, but it fills the fuel bowl very quickly when the key is on.
Well . . . I would say not but they are made in Mexico and I have had some IPR issues.Unfortunately I don’t have the old one. What are the chances of a brand new Motorcraft going bad?
No the filter was very clean.While you were looking in the fuel bowl, the filter wasn't dark, was it? (ruling out o-ring leak on injector)
Did you do the KOEO (key on, engine off) tests? And do you run a tuner?
Unfortunately it won't start so I cant do any tests while running.Also, did you read that ICP link I posted?
Did you do this test?
With your engine running, pull the connector, disconnect your 7.3 ICP pigtail. This causes the PCM to deliver a default ICP value of 725 PSI at idle. As apposed to the stock setting of 500-550 PSI at idle. There should be a noticeable difference in idle when you unplug your ICP.
Photograph your dashboard.
You really do not know what your IPR and HPOP are doing since the ICP sensor is not reporting properly.So just double checking my logic.
If the fuel bowl levels are good.
The IPR is building pressure on crank. You don't know this.
The ICP only builds pressure when unplugged but still no start. The ICP does not build pressure. It only reports if pressure is building. Since - when plugged in - there is no report of pressure, then you need to replace it with a known good to test it. That is why I suggested a cheap chinese part from an auto part store. $25 is cheap for a tool.
There are no codes.
That unfortunately leads me to think PCM. It is looking very iffy.
Am I correct in that thinking? Consider my notes . . .
I did these tests and the only one off was that B to ground was 300 ohms not >1000.Here is a link with Ford test data. Try these measurements.
ECSD - Injection Control Pressure (ICP) Sensor -...
Injection Control Pressure (ICP) Sensor Courtesy of: Ford Motor Company SIGNAL FUNCTIONS The Injection Control Pressure (ICP) sensor is a variable capacitance sensor that when supplied with a 5 volt reference signal from the PCM produces a linear analog voltage signal that indicates...www.thedieselstop.com
Yes fuses are all good and pressure to the fuel bowl is good.And your fuel pressure is where it should be , fuse and all are wright on ? Gov Holmes
Ugh. I will certainly do that. (Happy Hunting, Ha! I see what you did there)Ah! Time to chase wiring! With the Brown/White one that low, you need to find where it is shorted. That could be the cause of all your problems (fingers crossed).
First, make sure you check the plug and see if any of those short to the Brn/Wht. Could be a messed-up plug.
Then check your work.
3rd, unscrew the 10mm that holds the wire harness into the firewall / PCM. Once unplugged, check your Brn/Wht to ground again.
If there is a change, and Brn Wht is >1000 ohm, See if there is any damage. If not, your PCM may be toast.
If no change, unscrew the 10mm that holds the plug to the engine harness that is over the left valve cover.
Check the Brn/Wht again. If no change, the short is between the valve cover and PCM plug
If there is a change, the short would be in the IPC sensor plug and the Valve cover plug.
Happy hunting!
Do you know what (code 3-letter) is on your pcm?Ugh. I will certainly do that. (Happy Hunting, Ha! I see what you did there)
I may also get a PCM from a U Pull and pay that has a couple of same-year/engine trucks on the lot. They are only $15, so a quick swap could tell me if the PCM is indeed the issue. If it is, I can then pony up for the new PCM unit.
This is probably the issue. ^ I’d try unplugging your fuel bowl heater as a quick and free test… just in case.I did these tests and the only one off was that B to ground was 300 ohms not >1000.
I did an injector buzz test and they all passed.Have you verified BASE oil pressure? Have you done an injector buzz test?
Maybe i missed it but I don’t see you saying you didn’t. Your ICP value unplugged is inferred.
Have you verified adequate base oil pressure?I did an injector buzz test and they all passed.
I would send your PCM to DTC before buying a new one.
Link is in post 16.So I'm assuming that means I'm likely looking at a PCM issue? Where could I send it for DTC?
