1 - 7 of 7 Posts
99 f250 steering and brake are weak until i rev. the motor. i have to power into turns an the brake pedal goes about half way down b4 it gets stiff. would this be a break booster , or vacuum pump issue ? thanks for any suggestions .
super tuner
the powersteering pump runs the vacuum for the brakes so if you have weak PS and weak brakes then you probably need a powersteering pump,or you can simply flush the system with some ATF, i havent done it yet but ive heard it helps 110%
Strokin it in your face!
ummm hydro boost?
Discussion Starter · #4 ·
YEA ! I FLUSHED IT TODAY AN IT DIDN'T MAKE A DIFFERENCE, SO NOW IM WONDERING POWER STEERING PUMP? OR HYDRO BOOST?
1 - 7 of 7 Posts
