Ok so I have a 99 f250 superduty 7.3 that suddenly will not crank by the key if I jump the solenoid with a wrench it fires right up but the key will not even try I replaced starter solenoid and ignition switch still nothing I have tryed putting in every gear and it still won’t start when I turn the key the relay under the dash clicks and that’s it the trigger wire on the solenoid is getting 11ish volts when you turn key but nothing happens you turn the key and the radio turns off but none of the lights dim or anything I am a loss
