1 - 4 of 4 Posts
Hey y’all,
I’m new here but any help would be appreciated. I have a late model 1999 7.3 with 264,000 miles. I bought it from a dealership last year with 230k. It came with a 4” downpipe/straight back but was otherwise stock. The only things I really have done to it is add a TS 6 pos chip and a Napa Gold 6637 air filter. The truck ran great for 30,000 miles with reg oil changes etc. I’ve had it parked for the past 4 months but the story is, that I was driving down the interstate and it shut off. Started back up after a couple of tries and then ran another 500 miles without issue. Eventually I began to notice white smoke from the tail pipe and did the oil cap test which told me that I have a good bit of blow by...Enough to make the cap flutter slightly not just vibrate. Had it in to two different mechanics, first one replaced the IPR as the codes showed low injector pressure. It ran better afterwards and only seems to have an issue when at idle. Second mechanic did not do a full compression test but told me it would be a $13k-$14k rebuild. Basically, it always starts right up on the first try (and seems to run better after I used the hotshots Secret Stiction Eliminator to this recent oil change) but idles rough and puffs white smoke out of the exhaust until it gets warmed up. It otherwise seems smooth at higher RPMs. Thanks in advance for any pro tips.
Trust me, I got this...
Welcome! Maybe you could provide a video of the blow by? I've never heard of a truck just loosing a bunch of compression just suddenly driving down the highway, but I guess theres always a possibility. Does the smoke burn your eyes? Does it smell sweet? Cylinder compression numbers would be really useful for helping narrow down the issue.
Thanks for the reply! It doesn’t really smell sweet, and it doesn’t puff all the time it’s weird. I will try and post a video this evening of the blow by. Thanks again
Random thought... I'll second Cummins Junkie and say have the compression checked. I wonder if one of your injectors is not fully seated on the copper gasket.
Cj
1 - 4 of 4 Posts
