1 - 5 of 5 Posts
I have a built 99 7.3 and the oil pan gasket is leaking and the dipstick is leaking where it enters the block. Can you get the oil pan off to get a new gasket in there without taking the motor out??? Please help!!!
Your Daddy
No.
Well there was this one guy that cut out his crossmember and rewelded it back in...
STILL LEARNING
You will need to do this:eek:
We have done several of these jobs and always pull the motor. It's such a hassle for that job but it's the best way to get it done right.
Sent from Holderdown Performance mobile command center
welder/fabricator
the local ford gurus up here jack the cab 6" then pull the motor up on and angle and then replace the pan and evrything, you dont have to believe me but i watched them do it this way in under 6.5 hours
1 - 5 of 5 Posts
