1 - 7 of 7 Posts
I found this 99 f250 7.3 with the 5-speed for $4500. it needs a 4x4 actuator, a high pressure oil pump o-ring(leaking) and tires. he doesn't know what it needs for a safety because he's not a mechanic, but he said it runs and drives good. its got 204,000 miles(328,000km) is this a steal or should I walk away? here's the link: 1999 f250 8 inch lift runs drive 4500$ | cars trucks | Saskatoon | Kijiji
I paid $4500 for my 2000 ford X and it has 281,500 on it. I saw a good body and no rust, 8 inch lift $2000 right there
and its got some nifty hydraulic bed.... looks pretty good to me.
Yes those tires get expensive, I just got a set of 37s, set me back about $1800. but that was for 17 inch rims.
The manual is a huge plus the 37s for some nitto Mud Grapplers are $457 so you'd be about $6300 in to it off the bat but if you look at the Bluebook it is higher then you may think
Just buy it. Its a 7.3 what could be bad about that?????? :ford:
HPOP "o"ring.easy fix.
1 - 7 of 7 Posts
