1 - 20 of 43 Posts
Crazy wid da cheeze wiz
Bud... I dont know much, but I think its safe to say we need a little more information.
Super Hauler!
lol you expect us to help with that?!!!LOL:poke: what codes are you getting whats it doing? does it crank does it try to fire o what?
Dairy Mechanic
Any smoke? Fuel/oil pressure? It goes on and on for questions.
john
no smoke , does crank , does not try to fire oil is coming out the side of inj while cranking i tried a test on the inj wiring and it seems my cover gaskets r bad will this stop it from firing?
Super Hauler!
you mean you under valve cover harness (uvch)? yes usually one side only goes bad at a time so one bank will fire.
yes the valve cover gaskets send power to injectors and will cause it to not run.
im not really sure...we had those go bad on one of our trucks but the way we knew they were bad was that they had melted. they are kinda a pain to replace, attleast i thought so
well i guess they could be bad unless thats how they are supposed to be...idk but it could be your cam position sensor...they had a recall on those and that will keep it from running
hmmmm okay do you have a way to read codes?
well how bout now that you tried starting it? it should show some codes now
Davey B
When you crank it over does the tach move at all? Also, check to see if your wts light comes on when you turn the key on
im not sure...i would think it should throw codes if there is a problem even if it doesnt start
Headwind Magnet
What are you using to read codes? Most code-readers can't talk to a PSD. You need either a Snap-on reader or Auto Enginuity software for your laptop.
Best,
Jim
1 - 20 of 43 Posts
