97 f250hd,xlt,7.3,e4od,supercab,8'bed,3.54l/s f&r,285/75r16bfg ko2,rear airbags,
Im getting ready to order new front & rear leaf springs for my 97 f250hd 4x4 supercab longbed. Prepping for my d60 swap. As much as i really want to do the rsk for comfort, im not. I want to keep the weight of my 3000lb slide in truck camper as low as possible. I already chose the 43-516 2200lb leafs for the front to replace my tired 3486lb factory "Q" codes.
My rear leafs are factory "A" codes. My original research led me to believe they were rated at 2,810 lbs replacement spring 43-803. Specs say 4/1 leaves, 6 7/8" arch. Then on friday i called ats and spoke with junior. He mentioned that my original "A" codes were rated at 2,450lbs replacement spring 43-695 4/1leaves, 8 3/8" arch. So i spent many hours this weekend searching several forums and found both choices listed as original. I forgot to mention to junior that my truck has the camper package. So now im assuming the 2,450lb springs were on a regular 250hd and the 2,810lb springs came with the camper package.
Can anyone elaborate more on this and/or confirm this ??
I found charts that cary posted but were for newer rigs. I took some pix of my rear leafs. I will try to attach. Im not a mechanic but it looks like i have 3/1 leaves and a small plate.
