1 - 16 of 16 Posts
have a 97 obs with a sd turbo set up and cant get the y pipe in between the bowl and turbo. just wondering if anyone has run into this problem or a solution. any help would be great. also let me mention i do have an ic and 3in plenums. or if you know of any way to move the bowl without doing a efuel system?
thanks looks tough but i may not have any choice but to do so.
no ones really run into this bc most have done a efuel setup befor they got to a intersooler or for your mater a sd turbo its worth it, give that extra air some better fuel consistancy
I have the SD 3" plenums as well and could not fit the cast aluminum spyder. I ended up amking my own spyder out of two 3" mandrel bent 90* pieces of exhaust pipe.
It fits.
Discussion Starter · #6 ·
It fits.
got any pics of your set up? need some ideas i want my truck back on the road.
when I put in my E99 spider I had to weld up the holes in it to get rid of the plugs and I also left 1 bolt out of the fuel bowl and moved it forward a bit for extra clearance.
Why cant u just use a SD fuel bowl.
Whites Diesel Performance
SD fuel bowl bolts to the cover, youd have to swap timing covers F that just to run the turbo
U dont gotta change the whole front cover it bolts though the HPOP res not the front cover. U could bolt a SD HPOP res right on cuz, the 97 front cover is the same as a E99 just different HPOP res. Thats prob the easiest i think. thats my 2cents.
Just another OBS addict
A 96 has a different sumplocation thus a different timming cover 1/4 into 97 they changed to the same setup as a 99+ you need to look ay the serial number.
As for the op I have a y pipe to work with your setup
mine was very tight and i have to remove the y to change the fuel filter. i just got the y started in the plenums and shoved it in there
Drive it like ya stole it
Well my vote, if it matters, goes to doing Efuel set up. If you've got the funds I think you'll be happier with the performance over the mech system.
1 - 16 of 16 Posts
