If you check my signature you can see all my mods to my 97 psd. Now with you knowing what I have, I got an issue, since I modded my truck over a year ago it gained a higher and rougher idle, it used to idle 680 to 700 rpm or so now its going 610rpm to 720rpm sounding like its gonna stall out. This symptom only exists when the vehicle is warmed up or sitting in the sun all day.
When I drive I dont notice anything except maybe a litlle lag when I punch it, even in the 140hp setting, which wasn't lagging before.
I'm no mechanic but I don't think anything I have modded has broken, the motor has 225,000 miles with no rebuild and I know is low on compression could this be an issue? I'm thinkin it could be the fuel pump, I changed the fuel filter with no fix; and the fuel pump has not been changed since I modded the truck. I got a powerchips programmer to read the trouble codes only and DO NOT use it to tune with, but no major codes are showing, no check engine or other dummy lights on.
Any one have any suggestions? Any thoughts on this would be greatly appreciated Thanx for your time!!:ford:
