1 - 5 of 5 Posts
Automatic or manual transmission?
What did you TEST before throwing parts at it? What had you determined had failed?
The SOLENOID is part of the starter. Did you replace the RELAY on the fender?
Where are you hearing the click from? Can be hard to tell, but does it sound like it's coming from the relay on the fender, or down on the starter?
Have you tried turning the engine by hand, to determine that it's not locked up?
Did the truck run normally the last time you used it?
OEM Moderator
Bad batteries or bad cables seem likely to me.
^^^^ Def. high on the suspect list.
Tests - SHIFT TO NEUTRAL (we're bypassing the safety switch here...) and set the parking brake or block the wheels. You don't need the key in for these tests; this is just to see if the battery cranks the starter.
1) Put a jumper wire between the battery positive and the small terminal on the starter relay. If the starter cranks, the relay and starter, and battery connections, are all good, and there's a problem upstream - ignition switch, clutch switch, wiring to the relay, etc. If it doesn't crank, try test 2.
2) Put a jumper wire between the two big terminals of the starter relay. If the starter cranks, the relay is the prime suspect. If not, then the batteries or battery connections/cables/grounds are the next thing to check.
1 - 5 of 5 Posts
