1 - 20 of 25 Posts
My 97 regular cab I bought with a homemade rsk and Its on 37s so I don't expect a great great ride but its super rough And the front feels like it just bounces off bumps. What can I do. As far as I know the springs r stock and shocks look new so you would think it would ride close to a stock truck
Need more info....
Is the RSK with the stock IFS front end or a D60 Monobeam?
The PO of my sig truck did a D60 Monobeam conversion and used the stock IFS springs with an add a leaf on the front along with F450 spring packs in the rear. It rode too stiff and harsh for my needs so I swapped out to SD springs at all corners and its a different truck.
jrc
BROKE as a JOKE
yEAHHH.....mine rides a bit rougher than normal too. so i checked it today after pressure washing the frame...
i somehow missed the completely rusted off shackle mount when looking over this truck. the *&@#(&$ spring is resting ON the bed.
i have a bad feeling i should have walked away from this deal............
STILL LEARNING
Well now I know why it rides so hard. they added what looks like 3 extra leaves to the stock front springs. giving you about 6" total lift
Can you post up more pis of the welds on the RSK? From what I saw the welds dont look so great
Discussion Starter · #7 ·
How is that? The front only has like 3 leafs I'm it? That second To last pic is of the rear leaf spring. And yeah the welds don't look the best but Its also bolted in so Its not that bad. I wish This thing wasn't So hacked. If a rsk w SD springs wasn't So expensive And involved I'd Just do That
dam what a hack job. maybe go get some coin back if u can?
Dam, hack job for sure
Get with one of the vendors on here... they can get you setup with a nice rsk, and either a rear reverse shackle kit, or new shackles and hanger
Im pretty sure you can get new shackles and hangers from autozone/oriellys as well... then get a block kit and new u-bolts
STILL LEARNING
:whs:
This topic has been covered ALOT.....Use the search at top of page...
STILL LEARNING
needs more fuel
Discussion Starter · #19 ·
i hate to bring this back but i have another question, what if i took off the rsk and got 6inch front lift springs, would it ride better and does anyone have any measurements that would help me see if it would sit the same as now
1 - 20 of 25 Posts
