541 - 560 of 591 Posts
Native Californian
Nothing wrong with Luk clutches at all. I use them in all my trucks and I tow heavy quite a bit. It's no big deal to get 100k out of one.
Sent from my Pixel 2 XL using Tapatalk
Because I can!!!
Discussion Starter #542
I've always heard good things. I'm just normally extremely hard on **** I smoked a southbend in like 25kmiles once on my crew
Sent from my SAMSUNG-SM-G930A using Tapatalk
Native Texan
Thats cause u lika the burn outs
Sent from my SM-G970U using Tapatalk
Native Texan
Well theres nothing wrong with burnouts... or donuts or 4wd launches or anything of that sort
And theres maybe a reason ur poor clutch gives up the ghost.
Native Texan
I get to order transmission parts this week.
Native Texan
That's like an every week occurrence for me
This means i may here my truck run for the first time since early 2019 been a long time coming
Because I can!!!
Discussion Starter #549
We'll get it going! I'm gonna have to go catch up on your thread here soon. I've been slacking on my reading lately
Native Texan
I started then changed my mind ill have the money on Wednesday to order the last of the parts
Because I can!!!
Discussion Starter #551
I've got the cab completely gutted and what I need for the powerstroke harnesses cut in. For the computer itself I just cut the whole bigger qnd it fits like factory. As for the 2 wiring harnesses I had to rearrange them around on the firewall to work around the parking brake but I made it work. Rust is cut out and patched up. I definitely like fixing rust in spots that arent ever seen way better than on the body itself.
As for the bullnose my neighbor has I didn't end up with it. I made an offer and it was to low and he wont tell me what he wants so screw it I am gonna piece it together. I scored a rust free perfect shape radiator support for 100 bucks tonight. So the hardest part to find I now have. Along with a grille and headlight surrounds and these nifty original diesel tags for the fuel necks.
And also attached is a good pic to show what 31 years out in the South Dakota elements will do
PSN intsigator
Pretty cool, progress is always good
Because I can!!!
Discussion Starter #553
Cab and core support are both in primer. I got a new set of aftermarket fenders that were just delivered yesterday as well. I'm hoping this weekend to make a junkyard run and grab a hood, bumper, and the filler piece between the bumper and grille and a few small trim pieces and then I should have basically everything that I need to finish
CAT lover
Looks good man! But with all that work you’re putting in you’re not going to pull out the door dent? Or is that an optical illusion from the pic?
Because I can!!!
Discussion Starter #555
The bottom corner? That's where I touched up a thin spot in the primer. The on the front of the door frame? That's a goofed up spot that I never noticed until I sprayed the primer. Somehow I missed it while sanding and everything else
PSN intsigator
Looking good
Sent from my SM-N975U using Tapatalk
Native Texan
You want to come down to mo and do mine Looks good better then mine will probably
Because I can!!!
Discussion Starter #559
Ahhh it just takes practice this is my third time painting a vehicle and it just keeps getting considerably better
Native Texan
I only want to do mine once and i am now on try 2. But that looks awesome
