1 - 7 of 7 Posts
pics here
97 F-350 pictures by fsadmike - Photobucket
· XLT package (power everything)
· 6-position chip from BTS
· Remote start w/turbo cool-down timer
· Tinted windows
· ABS rear axle
· 3:55 gears
· Tow package, including electronic-brake controller (plug on bumper and in bed)
· Spotless cloth interior
· Brand new radio, w/ipod ready cable
· Warn premium manual hubs
· Factory block heater (w/unique plug-in)
· Tymar high-flow intake system
· Straight downpipe
· 4” stainless exhaust
· Triple gage pod on A-pillar (Trans, EGT, and Boost)
· MagHytec oversized transmission pan
· Extreme duty aftermarket transmission cooler
· MagHytec oversized rear differential cover
· LineX bed liner
· New lift, done right (call for details)
· Bilstein mono tube shocks
· Removable camping setup in bed
· Leer model 122 topper (absolutely NO leaks!)
· Professional diagnosis shows engine and systems are in excellent condition
This truck is immaculate! 2ND Owner! It has been well maintained from the ground up. The engine is so clean; you can eat off of it! Regular maintenance and many new parts have been added (see the following pages). Blackstone Labs oil reports show excellent wear characteristics, even at 200,000 miles! Before you shrug off the asking price, PLEASE read thru the records attached. I will entertain any reasonable offer. The fully negotiable starting price is $11,999.
Call or email Michael at:
719.599.3723 anytime before 9:30 pm
[email protected]
Removable camping setup in rear:
see photobucket link above for pics
· 43 gallon water tank
· Coleman on-demand hot water system
o Faucet or shower hose attachement
· 4" foam mattress on full length storage box
· (sorry, Powertank® in pictures, not included)
LOTS of room! Very well though out, and for one person, can t be beat. The water tank alone was custom built and cost about $300. The labor to build and the parts are worth a considerable amount. The 80"x30" platform on right side of truck bed has a 4" mattress on top. It is also storage box and there is additional storage in the area between the box and the truck bed wall. On left side of truck bed, a 43 gal tank, plumbed to the Coleman unit (pumps cold, warm, or hot). A lift up countertop between tank and the Coleman unit where I put my little grill and other stuff I set up when camping. The cooler fits underneath the Coleman unit. Between the cooler and the Coleman unit, a drawer with ball bearing slides. Great for bathroom and kitchen stuff.
Make me an offer for the whole package, truck and all!
The following listS are backed by
records, receipts, reports and invoices
(they are available on request)
· Recent work I’ve done:
o ALL fluids done at 200k (oil done every 5k)
o synthetic oil changes since 175k
o Glow plugs and glow plug controller
o Water pump
o Vacuum pump
o Rebuilt front drive shaft w/ greasable joints
o Radiator hoses and thermostat
· Some of the things I’ve had done since I’ve owned the vehicle
(countless dollars worth of replacements, modifications and repairs):
o Suspension lift done right:
o Superduty X-code front springs
o Icon Superduty 5” lift rear springs, eliminates rear blocks
o reverse shackle kit up front
o adjustable track bar
o 4º wedge shims for front axle pinion angle
o drop pitman arm
o Shocks
o Vacuum pump
o New batteries (with a serious warranty!)
o Alternator
o Steering gear box and high pressure hose
o Rear brakes, including one wheel seal
o Front brakes: pads and rotors
o Front wheel bearings and seals
o Upper and lower ball joints, universal joints
o All tie rods/drag links and ends
o Cam position sensor
o Turn signal switch
o Fuel filter heater, injector O-rings
· Original owner’s maintenance to include but not limited to:
o Rebuilt transmission ~126k
o Starter ~116k
maintenance records are in excel format. email for detailed 8 page flyer!
another bump, nice truck. i like the block heater plug, never seen one like it.
phone number says colorado springs, colorado.
1 - 7 of 7 Posts
